Jet-II Q5
ernsanada
I just received the Jet-II Q5 from Bug Out Gear.
You have to be a CPF Member to get this special price of $69.95.
There also is a thread on the Jet-II on CPFMP
Shipping was very fast, 3 days to Socal.
Uses a CREE 7090 XR-E (Q5 bin).
Input Voltage: 0.7-4.2V
Functions: Two Modes:
1. Advanced Mode 100%-Strobe(15hz)-10%-20%-30%-40%-50%-60%-70%-80%-90%-SOS(100%)-SOS(5%)
STANDBY(flashes once at 5% brightness every 6 seconds when in standby mode).
2. Daily Mode 100%-5%-(12Hz)Strobe. With memory function each level.
Reverse clickie.
The Fit and finish is excellent. T6061 Aircraft Grade Aluminum Alloy.
The Type III Hard Anodize is very good. A little mis-match of color.
Sapphire lens.
Comes with lanyard, extra o-rings, rear rubber switch cover and diffuser.
Cree Module, rear.
Rear switch, inside.
Fits AW's RCR123 snug.
Diffuser on.
In these beam shots I'm using the Jet-II Q5 and Lumapower D-Mini 1st Gen. Q2 SMO
Left, Jet-II Q5 SMO. Right, Lumapower D-Mini 1st Gen. Q2 SMO
I also took lux readings of both lights. These are the lux readings I got. I am using a Meterman LM631 Light Meter measured at 1 meter. I waited 2 minutes before taking the readings. I am using AW's Protected RCR123's which were fully charged.
Jet-II Q5 SMO RCR123 - 4070 lux @ 1 meter
Lumapower D-Mini 1st Gen. Q2 SMO - 6,000 lux @ 1 meter
Jet-II Q5 SMO RCR123 @ 87"
Jet-II Q5 SMO RCR123 @ 87" Stepped down exposure.
Left, Jet-II Q5 SMO RCR123. Right, Lumapower D-Mini 1st Gen. Q2 SMO @ 87"
Left, Jet-II Q5 SMO RCR123. Right, Lumapower D-Mini 1st Gen. Q2 SMO @ 87" Stepped down exposure.
Thanks for the review!!
picture are a thousand words! Thanks for ALL the pics! =].
would you happen to know the (claimed) lumen output of LumaPower D Mini?
Thanks for the review, Ernsanada. Can you possibly post the Jet next to a P1 or P2D for beam comparison?
Is that Q2 D-mini owning the Jet Q5?? Or is the Jet not being driven hard enough??
Many thx for review!
Can You measure current consumption (from battery) in LOW/HIGH mode?
Please... ;-)
With my Jet II using a 3V batery.
Doing some basic math.
3 Volt x .82 amps = 2.46 Watts drawn from the battery.
Let's assume an 88% efficient Converter
2.46 x .88 = 2.2 watts free for the LED.
Now if the forward voltage of the Q5 is say 3.5v
2.2watts / 3.5 v = 628ma being fed to the LED.
I think this is all correct.
As for low mode I just measured .04A. Note at this time the battery is down to 2.9v. It was just over 3V when when I did my measurements yesterday, I took the light to work last night and played with it a bit. (the pic was from yesterday)
Anyone else notice the threads are square, never saw that before.
The tail threads on my L1 are like that. I think it looks cool
Mine shows :
CR123 3V 950mA 4700lux/1m
RCR123 3V 780mA 4600lux/1m
RCR123 3.6V 500mA 5100lux/1m
Tryed it with AA enelooop, it was little tricky as I don't have
AA body for it. But results are very promissing:
AA eneloop 1.2V 950mA 3600lux/1m :)
Many many THX ;-)
Please, check current too in LOW mode(for me very intresting its max working time with small current consumption)
...thx, but Im electronic, I need "I measure", no "I think" :thumbsup:
Anybody can measure current consumption form accu/battery in LOW mode?BIG PLEASE :D
Here we go:
CR123 3V 50mA 290lux/1m
RCR123 3V 40mA 300lux/1m
RCR123 3.6V 30mA 310lux/1m
AA eneloop 1.2V 120mA 280lux/1m :)
The Diffuser has threads.
The Diffuser screws on to the battery tube.
Bruner on EDCF asked me a CR123 sized battery can fit inside the diffuser. If it can the next step would be to find somebody to make him a cap.
I have a Surefire CR123.
Looks like it might fit.
She fits!
The diffuser with battery stored inside will fit. I would not recommend this because you can cause damage to the Cree Emitter.
A cap should work.
Needs this threading.
The threads look like Acme threads they are stronger and don't cross as easily. Nice touch. :twothumbs
