Jetbeam BC20 battery question
Detox
Just got this off Amazon. Manual states 2xCR123 with no mention of using an 18650. Well, I tried my Nitecore 2300 mah 18650 and it fits/performs fine.
I'm a newer member and just want to know if there would be any adverse effects shoul continue to use this battery or if I should just get a pair of RCR123's.
Thanks
kj2
The Netherlands
eff
I have the previous version of the BC20. I've been using it with RCR with no issues. However mine is fitted with the XPG S2 led, not the XPG R5 that you find in the latest version.
Detox
Yeah I've got a few 18650's so I'll end up using those. I emailed Jetbeam today with my serial # just to be sure.
ChrisGarrett
Miami, Florida
Thanks
SureFire has marketed the K2 Energy RCR123s which are a nominal 3.0v, so they'll work in place of two CR123A primaries, but capacity isn't all that great. 3.0v RCR123s differ from 3.7v 16340s, even though the size is about the same. Using 2x3.7v 16340s, which come hot off the charger at ~4.2v will probably blow the LED, unless the light is capable of handling that 8.4v number.
If you get acceptable brightness out of a 18650, use that. Heck, you can even buy 4.35v cells, that hold a higher voltage, but need a 4.35v (3.8v nominal) charger like the Xtar VP2, or SP1.
Chris
