vetkaw63
Has anybody swapped their LED for a higher bin yet? How does it come apart? How difficult was it?
Thanks,
Mike
Thanks,
Mike
Took apart my CLE to remove lint behind the lens but haven't done this mod yet... Happy with my tint and output
The head will twist apart just below the knurling band after the glue is weakened with a heat gun or hair dryer. Inside you'll find an XRE mounted on a mini-star board that's much smaller than standard size star. Haven't seen this smaller star for sale, if it was available then the swap would be pretty much straight forward. You could also unmount the emitter using a butane gas lighter then re-flow solder a Q-bin in an old toaster oven.
HTH.
Looks like no reason to swap mine, fer now.The mini-star in the DealExtreme link is the same P4 flux bin used in the v1.2 CLE.
Good to know there are replacements available in case a re-flow mod goes wrong.
I finally got mine apart. It has 4 bond(?)wires. My emitter is glued down and, not with thermal compound. It looks like I will have to destroy the stock board to replace it. For that much trouble I may wait for an R bin.
If anybody is going to try this, be very careful or you WILL damage the light. There is a LOT of glue and very little to hold on to. Just the one ring of knurling.
Mike
which stock board you destroy?
the one holding the emitter or the driver board?
