andrewnewman
There is an electrical lubricant that a lot of companies use on moving electrical contact parts. It is supposed to be neither a conductor of its own or an insulator. That is because in the liquid state it is such a thin film so as not to inhibit contact yet still provide lubrication and help keep contacts in good shape so that they don't readily oxidize.
However. I have had experience with this mystery fluid in the past where it collects moisture out of the air and then it will freeze and cause contacts to separate from each other. I used to find this in potentiometers that had this material in it to minimize resistor element wear from the wiper. Moisture would get in on non sealed elements over time. If the RRT uses this fluid (and the thin film amount being used would be almost invisible even if you opened up the parts) and that area is not sealed from the outside environment then eventually it could bring in moisture and have contact problems when cold beyond that of battery performance. This would not be noticeable ever if you weren't cycling back and forth well below freezing temps.
Thanks! That's the best explanation I have heard yet! In fact it is consistent with the behavior I have noticed. The light only warms up minimally in my hand but just past the point where moisture is condensing on the surface from the temperature change. Next test is to leave it out on the wood pile for an hour in the cold and then sneak out and try it.
From all of the reports that others are providing, I am thinking that this problem is idiosyncratic to my flashlight not the entire RRT-0 line.
