Harleydude
- Joined
- Feb 17, 2005
- Messages
- 7
Since the Extreme is Surefire E series compatible would the head work on an E2D body with a 18650 cell? That would be a very nice setup IMHO.
Yours came with spare clickies? Mine didn't.
I don't have a dollar bill sorry~
And If you want buy for EDC, I recommend you NDI because NDI is more slim and NEI is bit heavier than NDI.
Are torch lumens the same as lumens or what?
Look like switches same as on the NDI...Speaking of switches, does the switch on the EXTREME appear to be the same switch as on the NDI, of does it appear to be sturdier?
Another question about the bezel. Does it appear that the bezel could be removed and another bezel subsituted?
Ask about them Your dealer will be better~Yours came with spare clickies? Mine didn't. Hmm, I'm concerned. I'm not even sure how I'd get the switch out in the first place, it seems like its in there pretty well, anyone know what tool can get this out?
Yes NiteCore Extreme have the same UI as a Nitecore Defender Infinity.Does the NiteCore Extreme have the same UI as a Nitecore Defender Infinity?
Nitecore Defender Infinity UI video demonstration:
http://www.youtube.com/watch?v=daFqQjRYgMs
Nitecore Defender Infinity UI sumed up in words:
Initial Position: Tightened head.
Mode: Maximum brightness or strobe.
- Loosen and tighten within 1 second to switch between modes.
Mode state is saved even after turning off.
Initial Position: Loosened head.
Mode: User-defined brightness.
- Tighten and loosen within 1 second to ramp brightness up.
- Tighten and loosen again within 1 second to ramp brightness down.
Switch off to set and save user-defined brightness level.
But just little changed~ when you change mode, You have to loose and tight with in o.5 second(not 1 second).
Only the prototype NDI had allowed for a 1 second delay loosening and tightening. All final production units have a 0.5 sec delay period. So it sounds like the Extreme and the current NDI's have the same interface.
I ordered mine through www.photongears.com (Canada), and I must say Eric seems like a truly first-rate guy. Ourstanding service, great communication, and super quick response. I'd put Photon Gears in the same category as Fenix-Store and Lighthound.Nobody in the US is selling them?
You'll need to email him since the Extreme isn't on his site yet.
