Hi guys,
I'm not sure which forum this thread should be in but since it relates to those of us modifying or building our own lights, I figured I'd place it here.
Quite some time ago I was messing with a BB750 and one watt LED in a build and I noticed that the current going to the LED was in the low 600 mA's when the circuit was hooked up to a single 123 cell. Since then I have shied away from trying to use a constant current driver above 600 mA with a single 123. The other issue at the time was the fact that 600 mA is almost double the spec on the 1W and a typical 1x123 light isn't boasting massive amounts of metal for thermal relief.
Well now we have the Luxeon III's and they can take currents of up to an amp. Just how much current can we provide to the LED using a single 123 cell? Tonight, I built a 667 mA BB and went to the trouble of putting one meter on the voltage of the 123 cell and another on the current to the LED. I used a fresh SF 123 cell. Before the first minute was up, the current was down at 600 mA and the voltage drop on the battery was at 2.05 volts. My test LED has a Vf of 3.3 at 350 mA so it's really on the friendly side. I don't trust my equipment let alone myself 100% on tests like this but it sure didn't seem that the 667 drover was able to run at spec! For the heck of it, I hooked the driver and LED up to my bench supply and set the voltage at 2.05 volts. The current to the LED was 667 mA and I noticed the current being drawn by the circuit was 1.8 amps!
I then changed the sense resistors to make the driver a 611 mA driver. I hooked up the equipment and again saw within less than a minute about 600 mA going to the LED and the voltage drop across the battery was just barely above 2 volts. I touched the IC and noticed it was definitely hot.
Frankly guys, I would like to see some of you electronic experts do some thinking and perhaps emphirical study on the capacities of some of these systems we are building! I hope I am wrong but I sense a ceiling of somewhere around 600 mA current to the LED on a single 123. I think using higher current drivers is not bringing more light out the front end?!?!?
I think one could do the math and figure out how much power is required but the voltage drop on the battery dictates how much current it needs to get you this power. What are realistic max targets for the 1x123 power pak?
I should mention that initially, the current and voltage measurements I saw looked good but you could watch the numbers just plumet in no time. I imagine if a lux meter had been mesuring the light output that it too would have started out high and then dropped.
Forgive my rambling and hopefully someone can set me straight here.
