Awesome pics! Be careful what type of batteries you use, I used the energizer rechargeables in it when I got it, and went through two sets because each time I had a battery that leaked. So, I got 16 Eneloops and have been using them for some time now, completely draining them twice and I haven't had a single problem. Enjoy it!
Great choice. From what I hear, the Duraloops are pretty much the same thing as Eneloops.I'm runnin' "Duraloops" from Costco in it. Still on their first charge and going strong.
-Mark.
Do you think if I just kept it off of turbo mode it would be better for the batteries and help prevent leaking?
It is bigger than I thought it would be, and it doesn't throw a focused spot beam, it's more of a "floody" light, but man, does it put a lot of light out. I also like the different settings. The low setting is about right for a low setting and the med setting is great for around the house serching for things you misplaced in the garage (long story). The high setting is pleny bright to let you see darn near anything you need to, and Turbo mode will let you look a little into the future.
-Mark.
