I hope I am not in the wrong forum for this, but this seems to be the place I need to go to get some help with this setup. This is an LED array for use over an aquarium. I wanted feedback on what pitfalls I may not be seeing.
First up here is the parts list (and I currently own all this save the optics and slugs which are "in the mail" so I am not talking out my rear here):
9 High Current K2 LEDs - White
9 High Current K2 LEDs - Blue
18 5w 1ohm resistors
15 grams of Arctic Alumina Epoxy
18 15degree optics
40 Copper Heatsink slugs
400w 12v PC powersupply already wired to turn on without MB
100% Silicon Caulk
I also have several (40+) small CPU heatsinks. I have additional K2s as a backup for burning out during testing and I have already smoked one due to poor heatsinking hence the Alumina Epoxy.
The design is simple. Epoxy the LED to the heatsink, solder them together with the resistors, silicon the optic on and screw them into a piece of wood. Each LED/heatsink will have a couple inches of wire between it and the next LED so I can yank burned LEDs out easily.
The circuit is pretty simple with 3 LEDs wired with a 1ohm resistor and then wire those in parallel.
So what am I missing here because I know it is something?
Ohh... my first test which smoked a poorly heatsinked LED or at least I think that was the problem after about 5-10 minutes of running. The other two are fine.
http://www.cameroncole.com/cgi-bin/...quarium_Light_1
Thanks in advance.
18 15degree optics
100% Silicon Caulk
Thanks in advance.
