Kathmandu Xenon Flashlight
Manual Man
Hi guys
I have a Kathmandu 2 x AA flashlight with a xenon bulb which I would like to try improve. Is it possible to replace the bulb with a brighter one with a higher voltage rating and replace the batteries with 14500s?...The current bulb is rated at about 20 lumen I think and is a bi-pin type (pins are 2mm apart). I'm pretty sure the flashlight is direct drive (if that means what I think it does).....oh and could any of you suggest a bulb that would work for this? (I can put up pics if you need them)
Thanks in advance.
