Kill a Ni-MH
how2
london
What the quickest way to kill a Ni-MH ?
To get is reading 0v permanently.
I don't want to use water.
I don't want an explosion.
Got some old batteries and i just want to kill them.
Take it to a battery recycling center or to a store that accepts old batteries for recycling. My workplaces have all had battery recycling bins in the various buildings.
Dead short for weeks. I have left several flashlights on for days and they always came back. It really didn't hurt the already bad capacity. I suspect that several weeks may do it.
As far as I know, the only way to get a nickel based cell to read 0.0 Volts is to have damaged the separator in such a way that it is shorted out internally. Otherwise, as long as there are chemicals inside the cell, and the electrolyte is not 100% dried out, there is going to be some voltage.
Dave
If you leave it shorted for long enough it will eventually get to 0 V. I came across some Targus brand 2700 mAh cells that were packaged in a charger without any plastic insulator to isolate them. Those cells read 0.000 mV on my meter. I couldn't even get a microvolt out of them.
Contrary to what I have read on these forums, I have never been able to "kill" a NiMH by totally zeroing its voltage. This may happen forgetting an incan flashlight on for extended periods of time. I have done this a few times with a 2AA light and always both batteries have recovered after a refresh cycle on a BC-900. It takes a little tweaking to start the charge, but after that, they've always worked. One of the batteries (the weaker one) has probably even experienced reversing, as some power has been pushed through it after it has been completely depleted.
I haven't done this on purpose, not with good, new batteries, so I can't really say how much of the lost capacity comes from this abuse. I haven't seen much change, though. Anyway, it seems that a NiMH won't die of this kind of electric abuse. Maybe it "gets sick", I don't know, but I've never seen a sudden death. Does anyone have more substantial numbers or something on the damage that should occur to a NiMH battery during a rock bottom deep discharge? If it isn't the capacity or current output, maybe it's the self discharge rate?
Reverse charging a cell is a good way to get it to grow an internal short, and never work right again.
Ok, but that's obviously a possible outcome, not an inevitable result of reverse charging. But are there other effects that will always make a gradual decrease of performance, so that a reverse charged battery is never going to be quite what it was before the event? Or is the internal shorting something that can also build up gradually, so that every deep discharege or reverse charging will just bring the inevitable death closer, just lurking around the corner but not yet showing its ugly face?
Can someone suggest good reading about NiMH battery chemistry? Why not different lithium chemistries as well. I mean, not just how to charge and use them, but the actual chemicals used, crystallization effects in the different phases of charge and discharge etc. Not that I'd like to found a factory of my own, I just happen to be interested.
Oh yeah, reverse charging one time isn't a sure deal for cell death, but from what I have seen it doesn't take much if anything more.
How about overcharging??. That be another good way to ruin them. Or a fast charge/discharge until they are hot.
