KL-1/Scorpion
Roy
Farewell our Curmudgeon Administrator
Granbury, Tx USA
Here's what the Sure Fire KL-1 looks like mounted on a Streamlight Scorpion body. Every thing works just fine!
ADDED:
The white band is where a ridge was ground off so an ARC LS head would fit on the E1.
Hey, that's cool lookin'...
Roy, is the bezel really as green as in the photo?
Added a picture of the E1/KL-1 to the first posting. The pictures were made on my Hp Scanjet 4400c flatbed scanner.
Linked from another thread, you would just take a KL1 head and scre wit onto the Scorpion body? If so cool, if my call to SL goes wrong and I am stuck with a compromised Scorpion, this may be an option.
Jason
Roy,
That runtime should be very flat, shouldn't it? It looks like it's not running in regulation.
CM
Roy - looks suspiciously like the wrong graph - says "e1" in the upper right corner... and should have about 4 hours of dead solid regulation, right?
Roy Said:[ QUOTE ]
[/ QUOTE ]
Now I'm really confused...
My BAD!
Had it linked to the wrong graphic! Was not suposed to be a runtime chart. Looks like I used the same file name twice, which kinda changes things. /ubbthreads/images/graemlins/crazy.gif
Can someone explain to me how you read one of Roy's run time graphs.
Re: How to read a Runtime Chart
The vertical axis is a measure of the light output of a flashlight either in mA (current output of a solar [photo] cell) or more recently, footcandles (from a calibrated light meter). The horizontal axis is time in minutes (5,10,15,30,60 minutes per division). I usually measure runtime as the time it takes for the light output to drop 50% from the brightest reading (usually the start of the plot on the left).
