KL1/KL4 hybrid
StoneDog
Suwanee, GA
:awman:
SOMEONE has to put a LuxV under the KL1's optics... That's about the only KL# mod that hasn't been done yet.
Garmin, If you like the KL4's beam with a Lux3, track down a Gen3 KL1 and drop in a U-bin Lux3, Wiz2 and sand down a 20mm IMS to fit. Mine (UYOK & Wiz2 917) is wicked bright and has a nearly perfect beam. The spot is probably a little wider than your KL4 and the spill is nice and strong.
Jon
grnamin
McKinney, Texas
StoneDog said:
:awman:
Jon
Jon, is the Gen3 KL1 the original style one with the Lux I, but with the scalloping on the bezel rim? If that's the one, then I think I may have a source for one. The owner of a gun shop in Connecticut (SF authorized dealer) showed one to me two days ago. I told him that it was rather rare. He has it for sale. :rock:
CM
Mesa, AZ
Well since no one replied to my last post, I figure no one will reply to this one either :( I tried the Lux V behind a KL1 gen 3 TIR optic.
grnamin
McKinney, Texas
How did the beam turn out? Pictures please.
Correction: I was able to open up the KL1 that arrived today, all the way through to the LED and optic. It wasn't that difficult to do. I have a better appreciation of the internal design of this latest version of the KL1. No need to center the LED by eye. Just pop it into the slot. Now waiting on a McR20 reflector I ordered from the Sandwich Shoppe to put into this KL1. :)
CM
Mesa, AZ
I held the optic in place so I can't take pics. I tried to adjust the distance from LED to optic and the best I've got is the image of the four dies--:sick2: But that was against a white ceiling. May not matter if you're looking for flood but I suspect if you want to use the TIR, you're looking for throw in which case you're better off using a reflector, and a BIG reflector for the LuxV at that.
BTW, the KL1 circuit can be used to drive a Lux V (I did it 3 years ago and it's the same circuit as what they're using today). The gen 3 circuit drives a lux at around 500mA. A poor man's KL4 is a Gen 3 KL1 with the optic replaced by a reflector and the circuit boosted to 700mA, with a WWO lux V. Use a smooth reflector, not textured.
Luna
you tease!
StoneDog
Suwanee, GA
Scalloped (saddled?) with optics and I thought a Lux3, but not sure. Here's a pic of mine (with HA stripped and polished).
After a long dip in Greased Lightning but before the polishing:
And after:
It's not an easy mod, the 20mm reflector doesn't want to fit right - I should've done more to the middle section of the KL1 so that the emitter could sit lower.
Jon
StoneDog
Suwanee, GA
Thanks, but it's been carried a lot since then. Bare Al just doesn't hold up, so this one exhibits quite a few "character marks" now.
Not wanting to hijack, sorry for the tangent. :)
Jon
IsaacHayes
Missouri
CM: Now the next big question is will a TIR from a KL3 2.5 work with a luxV???? (.5 means the one with the fresnel rings that gives more smooth beam/cornona/sidespill).
