KL4 modified with 15 watt Ostar LED.
ARC mania
The land of the rising sun.
Well, heres my all time favorite. A 15 watt 1000 lumen Ostar LED crammed into a KL4 head with a converter that has four levels of light. I had the 3 x CR123 barrels custom made with titanium clips. Enjoy.
ARC mania
To answer all your questions, the 15 watt Ostar is from a QZ bin in brightness when driven at 700ma of current. Since there isn't enough aluminum mass to keep the Ostar happy, it is under-driven at 590ma in high. Still its cranking out over 700 to 800 lumens (an estimated guess from a McR20 size reflector.) Yes, it gets fairly hot after 6 - 7 minutes in constant use in high mode. Not so hot to where you can not hold it. This mod has four levels of light, low-60ma, medium-150ma, medium high-250ma and, high-590ma. Minimum input voltage is 7.4 volts and max is 14 volts. Its electronically reverse polarity protected so no worries changing batteries in the dark. To make the light even smaller, you can use an E2e barrel with 2 x RCR123's. Size for size, probably the smallest 15 watt Ostar powered light on this forum plus the size for light output ratio is incredible. Before I forget, the beam is more of a flood than a spot. Regardless, it is bright.
ARC mania
Hit me upside the head with a realitycheck....!!!
That is one awesome build....!!
Have any pics from the actual making....?
To answer all your questions, the 15 watt Ostar is from a QZ bin in brightness when driven at 700ma of current. Since there isn't enough aluminum mass to keep the Ostar happy, it is under-driven at 590ma in high. Still its cranking out over 600 to 700 lumens (an estimated guess) Yes, it gets fairly hot after 6 - 7 minutes in constant use in high mode. Not so hot to where you can not hold it. This mod has four levels of light, low-60ma, medium-150ma, medium high-250ma and, high-590ma. Minimum input voltage is 7.4 volts and max is 14 volts. Its electronically reverse polarity protected so no worries changing batteries in the dark. To make the light even smaller, you can use an E2e barrel with 2 x RCR123's. Size for size, probably the smallest 15 watt Ostar powered light on this forum plus the size for light output ratio is incredible. Before I forget, the beam is more of a flood than a spot. Regardless, it is bright.
ARC mania
Thanks. You gonna sell any of these?
These mods are extremely difficult due to lots of detailed work. The inside of the head requires machining and I've destroyed several heads along with Ostar LED's in the process. I will make a couple more in the near future when I finish a few outstanding projects. I have no idea on pricing yet but will post in the near future.
ARC mania
:mecry:
Me wanted one...
Any price on these.....?
Thanks for the info BTW....:cool:
Well, if ArcMania said he might be making a few more just as recently as late July, maybe there is hope, but I know that he has mentioned that they are REALLY a PITA to build.
Price was $800, if I remember correctly.
OK.....!
Thanks..!
Just noticed this thread and have to say this is simply amazing.....game over as this has to be one of the brightest customs I have seen. Amazing work and clen as usual.
