So I decided to revisit the old MRV and change out the XR-E with a Nuetral MC-E.
I used a 650MCPCB from the Sandwich Shoppe to mount the MC-E on since 20mm stars don’t fit.
I put 2 pieces of Kapton tape down over contact pads to keep 4 of the legs from making contact.
I also lifted those legs slightly so the MC-E sits flat. Then I heated it to solder it in place.
I happened to have a KL6 driver in the parts bin.
The MC-E is wired up to 2s2p just like the old LuxV was internally.
But the MC-E will not see 700ma per die. From what I’ve read its around 300ma per die
I’m willing to risk the driver and bump up the current to see if the driver can handle more current.
I’ll be running it off 3*RCR123 or 4 CR123 and a spacer so its got head room in the buck to keep current draw lower.
I’d like some help identifying the sense resistor I should change to raise the current to about 1A to 1.4A
Is it A or B - Any suggestions as to values?
Pictures of the L.E.D. mounting and beamshots will follow after this gets sorted out.
And I’ll need to bore the smooth reflector to get the donut hole under control.
