Scott,
The switches themselves are too big in diameter to be hosted on the E2e body. I have personally made some progress with both 2 level and three level switches within the confines of the standard E series LOTC. I have working samples of both along with a pile of scrap and some almost working samples. /ubbthreads/images/graemlins/frown.gif
My take so far is that the L1/A2 switch is great and on a seriously modified L1 body hosting 2x123 and a modified head, a great and dependable package is available. Dang pricy and limited in terms of modularity though. I am about done with a couple of these that I plan to offer up for sale but they'll be pricy and were a fun but time consuming build.
The real answer is in a drop in replacement for the LOTC I think and I have been going nuts trying to nail something viable and repeatable down. I have one three level switch (modified LOTC) that will give you good range on an E1e with a boost circuit or an E2e boosting a 5W or buck circuit with a Lux III. In my experimenting and actual use of this switch as well as a couple two level switches, I have come to the conclusion that two levels is twice as good as one level but three levels isn't really three times as good as a single level. That probably doesn't make much sense but I think PK and SureFire knew what they were doing with the L1/A2 switch in terms of tactile function and limiting it to two levels. I am probably kidding myself here to a certain extent and justifying the pursuit of a more dependable and obtainable 2 level switch. /ubbthreads/images/graemlins/blush.gif Short of a complicated design with some injection moulded parts, special springs and some other happy horse sh$t, I don't think I can pull off a three way with any consistancy (made 5 and two worked and are working so far...) so I have now set my sights on the two way.
Below is a set of images of one of the three way protos that has been working well for a couple weeks now:
Click HERE for more info
Since this particular one works so well, I made more and half of them died almost immediately. Off axis loads on the pin contacts will mess them up and they will not "plunge" freely afterwards. Their positioning needs to be confined with some tight tolerance parts and ideally, they should contact a surface straight on and the surface should not be rotating as is the case in the design shown. There is a solution but it would take real $$'s and some close tolerance, custom parts.
For me, it's now time for some KISS design and a more realistic 2 level switch which is way useful in its own right!
Although these resistor type switches are not very efficient in terms of dropping the boost circuits out of regulation, you still get a useful low level of light and some silly runtimes in low mode. When used with a buck circuit, like the DownBoys, the circuit happily passes the LED into DD when Vin goes below Vf and there is an elegance in the simplicity and function, IMHO.
I think the Arc4 and Charlie's VIP will address the efficient provisions of multiple levels of output; not to mention some rumored SF light. /ubbthreads/images/graemlins/grin.gif
If I can pull off some type of simple drop in two level switch for the E series LOTC, I'll be real happy. So far I can only offer some talk which is cheap and some hope which is dwindling every time I stumble. But that's my problem. I had planned on keeping my efforts to myself until or unless they amounted to something worth mentioning or hopefully even offering. When I saw your post, I figured what the heck. Might as well spill the beans; uncooked as they are. It's funny. After a year of using the L1 as well as the A2, I am only now starting to really appreciate just how well they work and the value of what they provide. With so much going on, one often misses the real gems right in front of you!
And now for the short answer to your question. The L1/A2 switch won't adapt to the E series bodies.
