magnum70383
The Fenix L2D CE heats up quicky. It is normal for a cree led to have that much of heat?!?! Will it shorten the life on the LED because of the heat? It is a problem?
redranger97 said:Had a similar occurance here.. I was using mine periodically last night and I guess I forgot to turn it off before I slipped it into my pocket so before i knew it, something was just about burning my leg so i pulled it out and it was almost too hot to handle. I was alittle worried i may have fried it but it's been working just fine since. Btw, I was running Maxwell alkalines.
Lock-Out-Tailcap. It's not Fenix a feature (you can emulate it though) . LOTC is a SureFire patented invention.magnum70383 said:sorry but.. what's LOTC?
As Outdoors Fanatic said, LOTC is originally a Surefire feature. It's a little more sophiscated for Surefires, but for the Fenix, all you need to do is unscrew the tail-cap a quarter turn, and you won't be able to turn on the light. This is to prevent accidental activation in a bag, pocket, etc. It's due to the presence of anodizing on the screw threads, which prevents contact unless fully screwed on.magnum70383 said:sorry but.. what's LOTC?
selfbuilt said:As Outdoors Fanatic said, LOTC is originally a Surefire feature. It's a little more sophiscated for Surefires, but for the Fenix, all you need to do is unscrew the tail-cap a quarter turn, and you won't be able to turn on the light. This is to prevent accidental activation in a bag, pocket, etc. It's due to the presence of anodizing on the screw threads, which prevents contact unless fully screwed on.
I wish it was common on more lights, but you typically only see it on Fenix/Huntlight/Liteflux/Lumapower-grade of chinese lights. Hit or miss on streamlights, ultrafires, etc., and very rare on the cheaper knock-offs out there.
and don't go stressing that the batteries are dead!
Since we know that alkalines don't have the power to make this light so glaring light, could it be so that alkalines get more warm then Nimh cells because they are more stressed?
On aluminum lights with no anodizing, the point where the contact is completely lost is usually the point where the cap actually falls off. I have many cheap lights like this (including SL, minimags, ultrafires, EJY, MTE, MDXL, etc.). There are tips and tricks you can do to help block current flow through threads, but I've never really found anything that works well (except anodizing, of course).Lobo said:Is that a patented feature?😕
I have done it for ages on all my lights, even the cheapest of the cheapest. Just unscrew until you dont have a connection anymore. Can't see how there can be a patent on that, would be like having a patent on the wheel.
