NightTime
- Joined
- Dec 3, 2008
- Messages
- 152
My L2D Premium 100 died a few months ago. CPF's member “Marduke”, told me there were some bad recalled Rebel emitters put onto the market. Looks like I had one of those. I though I was the one who left the flashlight at Turbo mode for to long. Unfortunately there was no turning back as I already opened the head to sneak in. I removed the tiny Luxeon Rebel emitter and told myself it was time to try modding it.
I bought the Cree MC-E emitter and planned to use it. I know driving the MC-E with a 2AA powered flashlight was not the greatest idea. Especially with the L2D small reflector… but I did it anyway. I just wanted to have some fun doing my first mod... and hopefully I had some results.
During this funny task, I decided to take a few pictures in order to help or inform someone interested in this “upgrade”. As of today, I’m still not sure I really performed an upgrade. One thing I’m sure though is that I repaired my flashlight.
I rapidly got rid of the original Luxeon Rebel emitter so I don’t have any pics of it. Sorry.
The mod…
Opening flashlight’s head wasn’t so hard. Because threads of the head are locked with some stuff (see it as “locktite”), you need to heat up the head enough to soften the stuff but not too much. Doing so might hurt the circuit. Using a hairdryer is an idea. In my case my emitter was still working but it was very dim, blue and getting rapidly hot. So I took advantage of this last problem to soften the so called “stuff”. I used two rounded jaws pliers and two pieces of rubber to help for the grip and to protect the hard anodized finish.
Note that I did NOT remove the head from the flashlight to prevent the head to become deformed during the process. Remember that this is almost glued! Strength is needed here.
Time to cut the positive and negative wires. I cut them as close to the emitter as I could, but damaged them after. I removed the bad emitter by prying it with a small screwdriver while it was still warm. Was easy. I cleaned the area. Sorry no pix of the small Rebel :ohgeez:.
I discovered two things: a white plastic ring to prevent shortcuts that was lightly glued to the reflector and a donut-shaped-kind-of-adapter around the emitter AT the base of the reflector. I think Fenix was using it in order to fit the very small Luxeon Rebel emitter with their already designed reflector. It must be a cheap but efficient way to use different types of emitter with only one reflector.
Obligatory material:
Note that this is a 5 minute adhesive :thumbsup: (I waited 10 minute to make sure). Mix ratio is 1:1
Using small pliers, I changed the orientation of all 8 connections pins to help me soldering the wires and avoid any contact with the rest of the flashlight. Additionnal references given from CPF's member “mpf” : http://www.cree.com/products/pdf/XLampMC-E.pdf
I connected the pins in parallel as advised by CPF’s member “mpf”. I linked connection pins 1 to 4 together using lead. I did the same with pins 5 to 8. I tried to shape the melted lead (up) to give myself a chance for soldering my wires. I mixed my adhesive and glued the emitter.
The original reflector has a 6.00 mm hole (diameter). The MC-E emitter is almost 7.00 mm (diameter). So I oversized it using a drill bit (size "I"). I removed the burrs.
I did my best soldering the wires. I tried to had the excess of lead down in order to fit the reflector flush with emitter’s surface. The connector pins, the wires and the excess of lead is not in contact with flashlight’s aluminum block except at one place on the negative side. I don’t think this is a problem as flashlight’s body is already used as the negative.
Then I screwed back the head assembly. At that point, I realised that the white plastic ring was to prevent shortcuts and that my new emitter’s surface was not at the same level as the old one. Even if I fully screw everything the reflector is NOT sitting on emitter’s surface. See GAP #1:
Because of the reflector’s lip (as mentioned above on a picture) I wasn’t able to simply unscrew the reflector a bit to fit these new specs. So I completely filed down the lid. I forgot to take a picture of the result. That said and that done, GAP #1 is gone, but I now have a gap (GAP #2) at the end of the head. The picture above is not REALLY showing GAP #2. This picture was taken before filing down the lip.
Now the lens is rattling if I shake it. As shaking my flashlight is not a habit for me I’m OK with this ;).
Not shown here is an overhead view to show the emitter is centered in an acceptable way.
It's working! I kept it on low for ~20 hours, then ~1.5 hour on medium mode and then 5 minutes at Turbo to warm up the emitter. Maybe it's useless:thinking:. Did I gain runtime? I had no time to test. I doesn't look really brighter than the L2D Q5. BUT, because it's floodier then it was, maybe it IS brighter. I will try to test it. I will eventually also post beamshots.
Update no.1
Here are two beamshots to compare the beam profile:
First shot is the beam profile of a L2D Q5 with Orange Peel reflector @ 1 meter
Second shot is the beam profile of the L2D MC-E with Orange Peel reflector @ 1 meter
As expected, the beam is floodier than before. I'm glad I don't see the cross mark of the MC-E emitter. I start to see the cross at 0.7 meter. Thanks to the OP reflector.
I did a ceilling bounce test to compare the brightness. Comparing with a L2D Q5 (my L1D head with the L2D body in fact) I got this:
@ low, the brightness is exactly the same;
@ medium, the brightness is just about dimmer. VERY close;
@ high, the brightness is just about dimmer. VERY close;
@ turbo, the brightness is just about higher.
Adding my Olight T25 Regular I can sort them in order of brightness. From dimmest to brightest:
Fenix L2D Q5 - LOW
Fenix L2D MC-E - LOW
Olight T25 - LEVEL 1 (this is weird, I expected Olight's Level 1 to be the dimmest:thinking:)
Olight T25 - LEVEL 2
Olight T25 - LEVEL 3
Fenix L2D MC-E - MEDIUM
Fenix L2D Q5 - MEDIUM
Fenix L2D MC-E - HIGH
Olight T25 - LEVEL 4
Fenix L2D Q5 - HIGH
Fenix L2D Q5 - TURBO
Olight T25 - LEVEL 5
Fenix L2D MC-E - TURBO
Update no.2, Runtimes
I do not own a luxmeter yet, so I wasn't able to test the output from 100% to 50%. Instead I did from 100% until dead. I performed the test at Medium Mode using 2500 NiMh batteries.
The L2D MC-E lasted 10h57 until dead.
The L2D Q5 lasted 10h15 until dead.
That's 42 minutes more. I have to admit that I'm not very impressed. I repaired my flashlight, but do not enjoy a real upgrade. At least, I also had some fun!
Cheers!
The mod…
Update no.1
Fenix L2D Q5 - LOW
Fenix L2D Q5 - HIGH
Cheers!
