brightspot
- Joined
- May 26, 2003
- Messages
- 82
has anyone used an Aleph two stage tailcap on a surefire L4 from the sandwich shop. Just want to make sure before I order it 55.00
I'm not much of a modder. I was looking for something to screw off screw on. I did see the parts there in the sandwich shop. Does anyone put these together then sell them as a complete product? keeping it all Surefire would be goodcy said:works much better if you get internal switch only, then fit into Z52 LOTC cap. that way it's all surefire and matches.
The McE2S switch simply screws onto the tailcap of your L4 in place of the tailcap already on there; no assembly of any type is required.Katdaddy said:My apologies, newb question here. I have an L4 on the way and I am pretty sure I want to have the 2 stage option. What exactly do I need to order and is it something that I just screw on when I get it or is "some assembly required"?
Thanks.
Perhaps to clarify, the McE2s complete tailcap was once available but no longer seems to be. Other options now, besides asking on B/S/T, is to buy the internal guts of the McE2s and install that into a compatible tailcap of your choice. My understanding is that the current L4 tailcap, the Z57 clickie, isn't perfectly compatible but can be made to work. The Aleph tailcaps and original Surefire Z52 "lock out tail cap LOTC" accept the 2-stage McE2s guts. Some assembly required.The_LED_Museum said:The McE2S switch simply screws onto the tailcap of your L4 in place of the tailcap already on there; no assembly of any type is required.
http://ledmuseum.thefire.us/second/mce2s.htm
Two-stage switch and rubber boot pre-installed in a tailcap (McTC) is also an option.louie said:Right now at the Shoppe, it looks like the regular switch guts are available, either assembled (but not in a tailcap yet) or kit, and only flat tailcaps and McTC are available. Then you still need a rubber boot (button), unless you are putting the guts in an existing Z52 tailcap.
