I took delivery on my second BC-900 from Amazon about 5-6 weeks ago and its version 32 firmware.
jtr1962 said:Yes, version 32 like pretty much everyone's here. I wonder if they did a board redesign with version 33 or just a software change.
regnim:regnim said:Sent my charger to La Crosse on 1/11 and they received it on 1/13. Today, 1/17, I got a replacement. Firmware version 33. Put a fully charged set of Energizers 2500mah in it and set it for 200ma charge. Unit charged for about 10 min and then went to "full". So far so good, now trying the test mode, on my glass desktop just in case. No note or any reply, wonder if they even looked at my old charger, just sent a replacement.
wptski said:regnim:
Did you send/receive a new power supply too?
Mike abcd said:Charging 2500 mAH cells at 200 mA is just asking for trouble IMHO. All the cell manufacturers warn about using -dV/dt at low charge rates because the peak is very small or non existant. The reported lower temp cutoff of the V 33 firmware should help but the 200 mA rate won't do your cells any favors.
Mike
wptski said:I wonder if the user in this thread:BC-900 Meltdown ever got his replacement and what version it is, 32/33?
I tried calling La Crosse about my BC-900 twice and got dumped after a few minutes to voicemail! I left a message the second time. They might be closed today because of the holiday!
EDIT: I emailed them also!
regnim:regnim said:I sent them the charger and supply, they sent me a complete new charger/supply/case/batteries.
mccavazos said:Where does it list the version on teh charger? I still have the melted one, until I have time to send it back, so I can check the version on both of these.
regnim said:Yeah I know, but I wanted to be sure it would shut off and it seemed to work fine. If the power was interrupted while I was away it would start charging again at 200ma and I wanted to be sure it would shut off. 10 min probably did not hurt the cells any.
BVH said:Does anyone have a source for a very quiet, 120 volt, miniature fan that moves just enough air to cool the charger/batts?
wptski said:tacoal:
What do you mean that the charging current has a glitch now?
