I'm trying to see just what the out put of my laser is. I have tried comparing the output of a known source(solar panel) before and after being hit with the beam and also measured the volts and mA at the 3 wires going into the module from the circuit board. The solar panel results were inconclusive as the wavelength is probably not registering. I am reading 3.0 volts and 39 mA (using a 6v power source) at the junction of the board and the brass head.
Can this be? Am I testing the right things?
Using Ohm's Law that is 12mW from a laser pointer?
I have searched CPF and the LED museum for the correct procedure and I guess I missed it .
Matt
Matt
