Lathe motor problem
Packhorse
New Zealand
I am having an issue with my 240v single phase 1hp motor for my lathe.
The other day it was making arcing noises when I started it up.
Yesterday the arcing noise had gone but when I turn the motor on it would go very slow and I would have to give the chuck a spin by hand to get the motor running at normal speed.
Anyone got a clue what the problem is?
I am thinking it maybe the capacitors or it may be the bushes but I dont really have a clue. Im a 12v DC kind of guy.
No brushes on an AC induction motor, so it's either the starting cap or the centrifugal switch. The cap is easy to test & replace but the switch is not.
If the cap is bad I bet you anything it has leaked, if that's the case they are quite cheap. If it's the switch new motor time.
Hope for the best. Some digital meters have a capacitance measurement function. Remove the capacitor under the "bump" on the motor and check for the value written on the side. Test the capacitor with the proper meter. If the value is more than 20% off from the one marked, replace the capacitor. They are available from some electrical supply houses and motor repair businesses.
I have gone through 3 start caps on my old HF 3 in 1 machine in the past 5 years. It sounds exactly like a start cap to me. I now have 2 spare's lying around. My motors have 2 each.
Mac
Thanks guys.
I have 3 meters one being a Fluke scope meter and none have a capacitance meter.
I guess I will just try swapping out the parts which should be easy enough as they are external.
I have two digital meters (not Fluke) and both of them have capacitance ranges. They even agree with each other. No scope-meter, but I do have an O-scope. Sounds like you need a fourth meter.
