lawn boy battery charger
chewy78
wi
If there's just a slight chance you may want to use the charger for a vehicle some day in the future you may want to look at one of the Schumacher's at Walmart, such as this model:
http://www.batterychargers.com/ProductDetail.aspx?ProductName=94026717
http://www.walmart.com/ip/Schumache...Maintainer-and-Charger/13005742#ProductDetail
The charger has a push connector for both leads, and with a little luck it may be the same connector that you can use to connect to the battery. Otherwise, it will involve making your own adapter.
This one at harborfreight has a good review too:
http://www.harborfreight.com/15-amp-three-stage-onboard-battery-charger-maintainer-99857.html
(Despite the link it is a 1.5A charger, not a 15A charger.)
