HarryN
Hi
I have an idea which is sort of sacriligious, but I thought I would ask for some input before I try it.
I have seen an IRC 1205 LDO datasheet, which is nominally rated for up to 300ma and available in a variety of output voltages.
So here is the idea
- 2 x 123 cells (nominal 4 - 6.5V during lifetime.
- IRC 1205 LDO chip set for 3.6 V
- No caps on Vin or Vout, just the chip
- Direct feed into a 1 watt Luxeon, nominal 3.1 - 3.4 Vf
It seems like since the Vout from the 1205 will sag from 3.6 to nominally 3.1 - 3.3 volts as it tries to feed the 300 - 400ma, it will reach some kind of natural (but perhaps not entirely predictable) equilibrium with the Vf curve of the LED.
Since there is plenty of current available from 2x123, a cap on the Vin seems extraneous - ideas ?
Since Vout is not that critical, then a cap on Vout seems extraneous - ideas ?
The 1 watt LED will be most likely under driven, but even if it is running at 200 - 500ma, I am ok with that.
If this works, then I could use this to make a single chip (no extras) essentially "semi smart" resistor and skip a PCB altogether.
I am expecting efficiency would be 50 %, maybe 60 if I am lucky.
Now we are down to 50 cents for a simple, small regulator, which would seem to be at least as efficient, and more stable than a simple resistor.
Comments ?
So here is the idea
Comments ?
