I do!!:twothumbs Who cares about scissors? :poke: :D
I do!!
I emailed them about this and they said they will be following the design of the older Supertools ie. no scissors!!
I find that there is almost always a substitute for the other implements but never one for a pair of scissors! I'll stick with my Gerber suspension for now.
I like that fact that they're keeping with a classic design, but I also understand that most people do need scissors. :thumbsup:
I am boycotting leatherman. Most of their tools have 3 flat head and only one philips head. This is just dumb. Philips head screws are used for more often than flat head screws.
I need to see this in person, can't stand how bad some of the stampings are
What makes this better than the Super tool 200?:confused:
Agreed, I'm asking the same question.
I also wonder why the blades open only from the inside?
The Surge, Charge, and Wave are so much more handly with blades that open from the outside.
What exactly does the 300 do that the others don't????
It doesn't do anything the others don't, nor should it. All subsequent models, ST 200, Core, ST 300, appear to be refinements of the original Super Tool, not really new models. I liked the original version, thought Leatherman got it right with the tool set, but was put off by the clumsy and potentially dangerous lock release system. It was no deal breaker, though. I carried one for years, relied on it for everything but scissors, which was provided by a Micra. I even got used to the lock release system, appreciating its simplicity, at least. The ST 200 release levers helped some, rolled edges on the handles made the pliers more comfortable to use, but that was offset by the placement of the levers, which were a nuisance when gripping the tool for anything other than pliers. The Core corrected that with much better release levers, plus larger blades and improved implements that didn't clump (although that never bothered me). If you have an earlier version ST/Core, there may be no good reason to "upgrade", but there are millions of people who are potential customers for what I consider the best no-nonsense multitool on the market.
I personally prefer inside blades/tools on my Leathermen, as I always carry a primary knife for my cutting tasks, and only use the blades on my LM tools for secondary tasks or if I need a serrated blade for cutting. The inside blades like on the older tools and still present on the Core (one of my newer favorites) makes a much slimmer, tidier package when closed, and I can't remember the last time I needed to whip out a blade on a LM tool quickly, so that having inside vs outside made any appreciable difference to me.
I'm just glad LM has chosen to make both kinds of tools, not just inside or outside opening tools only, as I can see the perceived need for outside vs inside, its great to have a choice. As for the Supertool 300 specifically, about the only advantage I see it having over my Core is the replaceable cutters, so I doubt I'll pick one up, I have too many LM tools already (more than 15, with another in transit as I type this).
