LED 12 volt
jawnn
a funny farm near Seattle
I need a small add-on motorcycle head-light that will run on 12 volts... or possably 6 volts? (Not a whimpy bicycle light.) what and where??
I'd suggest looking thru the bicycle lighting forum. Some of our members have some spectacularly bright headlamps, and you could ask to purchase, or learn to build. I would suggest also listing some more specs. As in: flood or throw, cabled (powered from with a cable) to bike or built in battery, output, etc.
Little triple MC-E or P7 setup would be interesting.
PS
This subforum is about headlamps you wear on your head. There are other forums for automotive and bicycle.
I dont care what lind of light I get/ build ...I just need a really bright one, 200 lumin or more LED
[PS
This subforum is about headlamps you wear on your head. There are other forums for automotive and bicycle.[/quote]
^^^^^^^^^^^I'm trying to reiterate my previous point^^^^^^^^^^
-Is this for a motorcycle (or dirtbike), or a mountain bike?
-What voltage will be available?
-How many watts of power will be able?
-Do you want this to be attached to your bike with a cable (as in powered by it), or have a seperate battery pack from the bike?
-Are you looking for more of a spot (see further away) or flood (light up your immediate surroundings well)?
AGAIN!!! ask a moderator to move your topic to the bycicle sub forum, and take some time to look around at what others have done. Ask a moderator, because doubleposting is not allowed.
