First of all:
I love this thread! :)
A lot of home made direct-drive LED stuff only works with the battery it was designed with because perhaps the designer didn't realize that the properties of the battery itself were limiting the voltage and current through the circuit. Perhaps the designer was attempting to come up with a cheaper solution by using direct-drive of the led (with or without a limit resistor?)
Example: With no calculations or math, using simple :poof: trial-and error, someone manages to come up with a driver-less direct-drive LED circuit that works when powered by "12 volts of specific button batteries." The tinker then hooks his circuit to a 12v car battery, thinking it "should work." Most likely, the circut blows. Why? The driver-less build relied upon resistance (reactance) of the LED and internal resistance of the battery stack to not explode. Different batteries have different capacities and each one has its own internal resistance. These things, of course, affect the circuit. Note: Button cells tend to supply extremely low peak current.
Related search terms: "internal battery resistance," "peak discharge amperage," "voltage sag," "current-limited regulator," "voltage-limited regulator."
The solution is a driver circuit of some type, although you can usually get away with tinkering with specific batteries and a limit resistor. This is also called "driverless" or "direct drive," and some implementations try to even leave out the limiting resistor.
Warning: using different (higher current capable) batteries may well :poof: fry your home made experiment if you try this method.
Also: I completely agree with everyone else in this thread stating that each specific led might have different electrical properties than another one of the same type, even same maker.
Thanks, that's another question I had, what would be the difference between using, say, the 12V 1.5A psu and a 5V 4A psu (let's assume using a driver that can handle either, like a b3flex)? Could both power the led with to it's max brightness? Any advantages/disadvantages to either option?
If you've made a driverless circuit, the 5v psu with its 4a max might very well blow something that the 12v 1.5A psu will not. If the circuit design relies upon the PSU to *NOT* provide the full current that the electric circuit is "asking for," then it could definitely blow with other power supplies.
Another way to say it: A circuit that depends on "voltage sag" to not catch fire is definitely vulnerable to different battery types.
As always, someone jump in and correct me if I'm wrong please.
