LED blinking circuit
zmoz
Oregon
Can somebody please point me in the direction of a circuit for one or a few LEDs to make them blink? Something simple for someone that can barely strip wires? /ubbthreads/images/graemlins/smile.gif
If I am not mistaken, you can buy LEDs at RS that blink automatically without any external circuitry to cause the blinking.
You can also build a simple LED flasher that will run off as little as 1.5V using an LM3909 and a couple of other components. All parts are available from Radio Shack. This circuit uses very little power, so it will flash for a LONG time. Schematics involving the 3909 should be readily available; check RS's Mini Engineer's Notebook series.
Or...you could go with the flashing LED. It depends on what kind of "flash" you want. The 3909 circuit produces a strobe-like burst of light, whereas most flashing LEDs have a 50/50 or 30/60 (on/off) duty cycle.
I know about the one's that flash on their own...but they are pretty weak LEDs. /ubbthreads/images/graemlins/smile.gif Anywhere online I can find schematics for this?
Well, I don't know how useful this information is going to be to you...National discontinued this part back in 1998, and no one else makes it. /ubbthreads/images/graemlins/frown.gif /ubbthreads/images/graemlins/mecry.gif
Too bad, this was a really cool chip. You could even use it as an oscillator that would directly drive a speaker. A single C cell would power this thing for over a year flashing an LED...
You can take a look at National Semiconductor's datasheet on the LM3909.
I also found this which depicts the 3909 wired up to a 1.5V cell and a single capacitor. Larger caps will yield slower (but brighter) flashes.
I do not think Radio Smack carries this part anymore. I can't find it through any common distributors (Digi-key, Jameco, etc.)...so it looks like this may not be an option...sorry!
Damn...what can I make it out of then? /ubbthreads/images/graemlins/tongue.gif
The 555 will work, but it's quite a bit of overkill and horribly inefficient for flashing an LED. There's also a hefty minimum voltage requirement.
Perhaps a simple transistor oscillator circuit would work?
Manufacturers of semiconductors have datasheets on their products, for instance, http://www.national.com. These datasheets include descriptions, pinouts, and sample applications useful for design.
Well since no one else is going to offer you a circuit I will. Try this one, you can get all the parts at Radio-Shack. I produces bright adjustable pulses ranging from about .5 hertz to 4 hertz flash rate.
I see a couple of people here took a look at this post, has anyone tried the circuit out yet? I'm thinking of starting an eletronic circuit data base IF THERE IS INTEREST ONLY OTHERWISE I WON'T.
I'm interested.
As for his circuit, I thought the idea to use an LED with a built-in flasher was by far the simplest. To blink many, you can use that LED in series with others, or you can have it drive a transistor.
the built in flashers run off of 12volts only no chioce of led either.
[ QUOTE ]
[/ QUOTE ]
Ahhh, but the poster was looking for simple and readily available. I also suggest that the CMOS version of the chip would probably much more efficient than any discreet transister circuit. The CMOS version works down to 1.5V.
You can fool with the nearly indestructable LM555 and then upgrade to the pin compatible CMOS 555 when you get some experience.
Simplest is the self flashing LED, generally two flavours 12V which will flash happily on a 9V PP3 battery and 5V which will operate down to about 3 Volts.
With a PP3 battery clip and some hot melt glue you can make a neat flashing marker light.
Can also wire a couple of `normal` hyper bright LEDs in series with the flashing LED to get hyper bright flashing LEDs, no resistor required.
Or wire a couple of flashers in parallel with a non flasher in series with them and get an interesting flicker light.
Think a database of circuit ideas is a great idea.
Adam
I also have a a adjustible flasher circuit that works down to .8 V of input voltage. I will try to post it along with some other dc-dc converter circuits and PWM dimming circuits I have designed over the years.
Here is a circuit board made from the diagram above. The high flash rate is cool almost hypnotizing.
