you can check th stickies and welcome mat.
for Your questions, You are roughly right:
there is no big electrical difference for white led, they all run on - more or less - identical current and voltage
as to brightness: correct, the new ones (Cree XR-E and Seoul P4) give roughly double of old Luxeons, at same current and voltage. Refer to
binning for more info
color: thats the
tint of the individual led, ranges from yellow to blue, I'll search for a good explaining thread in seconds
... generally newer led tend to be more stable, with - again - a plus for the cree, where the bins and tints are the smallest range, while a single Luxeon or Seoul bin usually covers several of Cree's bins.
[edit] check this thread here:
http://www.candlepowerforums.com/vb/showthread.php?t=156772
shows the individual tint range of a good number of led [/edit]
Also the newer Luxeon rebel is considered here to be almost as bright as XR-E and P4, and to be more on the warm output side.
I just can type: got a few identical Rebel using lights and their outputs ranged from white (not warmer white) to ugly blue, with most of them on ugly blue. Unfortunately was nto able to order a special tint, ...
5 Rebels surely is not scientifically correct, but I have learned my lesson - stay with Cree.
Then there are the new multiemitter led, who house several emitting die in "one led".
Seoul P7 being 4 individual led, as is Cree MC-E and the 4-die Osram Ostar, then there is a 6-die Osram Ostar and several other makes
(the Seoul and Cree, again, giving about double the light at same power)
These are
