Hi everyone. I need to accomplish one task. I am looking for a way to connect 10-20 LED bulbs to a battery and be able to light them with a press of a button. However, same button should light each addition LED light. For example, first push of a button lights one LED, second push lights one more LED, and so on.
After doing some research I didn't really find any good solution. One of them is building PCB with programmable chip. However, I am looking for smaller (in size) solution. Perhaps some kind of relay where I can connect LEDs on extended wires.
Another solution I was thinking connecting lights in serial and controlling power with slider. For that I will need special LEDs that will turn on only when certain power level is reached. Don't really know if its possible, since I don't have enough knowledge in LED.
I want to also explain what it is for so maybe someone have better solution. I need to be able to put 10-20 LED lights in the beer mug with frosted walls. Put a little push button (or slider) on handle. And be able to control amount of LEDs on with just one hand.
Thank you in advance
