willpearce13
- Joined
- Mar 31, 2010
- Messages
- 3
I am currently manufacturing a high power LED garden light.
I am using OSRAM Golden Dragon LEDs alongside a 30W LED driver http://www.locksonline.com/acatalog/24v-15-or-30w-hd-led-driver-9096.html#spec
Does this setup seem feasable to you?
I am looking to solder some OSRAM Golden Dragon LEDs to an aluminium based PCB, but all the sites i have looked on require you to send your design and they manufacture it for you.
Here is a link to the LEDs i am using.
I was wondering if it is possible to solder the LEDs to a normal FR4 PCB board then using a thermal epoxy, glue it to a thin sheet of aluminium to deal with the thermal management issues.
The Golden Dragon LEDs are supposed to be reflow soldered, but i don't see why they cant be soldered using a normal soldering iron, but i was wondering if the PCB board would be able to dissipate the heat through itself and onto the aluminium sheet to act as a heat sink. Or would the PCB board warp under the high temperature. (max temp of around 70 celcius/158 farenheit)
The PCB with the aluminium base can then be screwed onto a larger aluminium heatsink to take away the heat.
Any help would be great!
Thanks,
Will
Thanks,
Will
