On the reverse polarity thing...don't some of the lights have protection for that? Does it work?
Reverse battery polarity.
EDIT: I should clarify, reverse polarity doesn't typically damage the LED itself (which, still functioning as a diode, blocks current with reverse polarity), but most driver boards release the dreaded magic smoke when power is applied to them backwards.
Smoke would be bad.
I am new to LEDs. I am totally sold on them--LOVE them.
so here is my question--What kind of unique issues do you have with LED lights?
Only A Light That Uses The Direct Drive Technique Would Be Damaged
No, only a light that uses a driver without reverse polarity protection will be damaged. Reverse polarity won't do anything to a direct drive light.
The reverse breakdown voltage of a LED is very low, And since the supply impedance to LEDs is inevitably very low, a heavy enough current can damage the LED.
It was my understanding that:
-Accidentally Touching The Dome Of The LED
What can happen if the dome is touched?
We have touched the dome of a P7 quite a few times and it seems to work fine still. We took the Bezel or head out because we want 180 degree of spill at that time.
Chip weevils?! you must be joking, right?
Please tell me that you're joking!
Oh OK. Will avoid touching it again.
It felt almost like silicon when touch.
