despite what You mean here or in Your other tread, You will definitly need an optic or reflector. Else any Luxeon is same useless than XX px. of 5 mm led. If You want the leds to give some kind of light for driving, then You need a very tight beam (any reflector or an optic not over 10 degrees), if You want showlight effect, then optic with flood beam.
(btw. I doubt the light will be enough for driving, but as I suggest 6 Luxeons, I have no clue what this number will really put out)
imho the easiest and best way for You is one of the optics that can hold 3 pc each of the lux (Carclo optics I think), 10 degrees or wide beam, given Your needs.
Compared to 5 mm ones, luxeons and especially 3 and 5 watts will need a MASSIVE heatsink + airflow (+ best a mounting made from metal to the frame of the car, to pull some heat away) Unlike normal filament bulbs, led are very heat sensitive.
(PS, other thing unusual to 5mm led: if You connect the 5 mm the wrong way, it wont light and You can switch contacts. The Luxeon is dead then. WATCH POLARITY BE4 APPLYING CURRENT!!)
