smflorkey
The hole in the SureFire E2 reflector for the lamp looks a little over 6mm. What is the brightest LED that will fit through that hole without drilling it out bigger? I don't want to cut either of my E#W heads yet.
:thinking: I don't see many options to enhance my new E2W. I'd like to be able to "drop in" a brighter, more efficient light engine so I figure I'll have to mount an LED on a brass rod mounted on a brass disc. I cannot afford a little lathe so it will be interesting to put everything together with the tools I have. I almost wonder if I should start with a brass 1/4-20 bolt. First, I want to make sure there is an LED that is worth the effort.
Thanks,
Steve
Thanks,
Steve
