lightinghelp
- Joined
- Sep 6, 2009
- Messages
- 8
I am unsure about the input voltage of a few DC led assemblies that I have.
Most are 12v automotive brake lights. Some have 9-15v written on them others have 12-24v on them and some say 12v only.
If I give these lights power from a higher voltage battery, say 18v DC or 28v DC will the lights work? Will they only draw the 12v that they need or will they break because of the high voltage?
Here are some links to the lights:
http://www.beachbuggy.com.au/Prod_Access_Product_View.asp?ID=79
[FONT=Verdana, Arial, Helvetica, sans-serif]Rear red stop/tail light with chrome bezel Large
A very smart looking American designed light. 5 year warranty, ADR approved, 12 volt LED
overall size 200x93x27mm
flush mounted
matching indicator lamp available
[/FONT]
http://www.buytruckstuff.com/ledlights.htm#
Thank you in advance.
flush mounted
[/FONT]
- 15 diode LED light design for 4" model
- 12 diode LED light design for oval model
- Polycarbonate lens and housing
- Patented reflector and optical lens enables 180 degree viewing angle.
- Voltage range: 12 to 38 volts
- Meets both FMVSS 108 & ECE photometric requirements. Does not require top positioning.
- Meets SAE J2261 when used for front turn signal indicators.
- Warranty: Unlimited Lifetime
