REDLINEVUE
Can this be fixed?? Or am I being too critical? If it can be fixed, can it be done somehow myself or do I need to send it back?
100% Crop
100% Crop
Also based on my experience, it makes absolutely no difference in the beam quality.
Can this be fixed??
Chances are, that if it bothers you, its going to continue to niggle you every time you look at it.
Call it OCD, anal, what you will, unfortunately that's the way it is with some people, me included.
Because of the positioning of the 4 metallic connectors on the slug of the SSC-P4, I find that any off-centering is all the more obvious.
I have corrected this on 2 of my PD-S lights simply as TB suggests, which is by unscrewing the bezel ring then shaking or slapping the sides of the head until the reflector is in a more centered position and then carefully trying to tighten the bezel-ring whilst not disturbing the reflector.
This can take many attempts and quite a lot of patience!
I can fix it for you. Or even upgrade it if you are interested.
