I have a flashlight with a bi-pin socket. I figured out which terminal (pin hole) of the bulb socket is (+, aka battery head, aka battery front) and which is (-, aka battery tail, aka battery back).
I have a uni-directional LED that when installed the wrong way, will fry. The LED has an anode (+) and a cathode (-) clearly indicated.
Question:
1) Do I connect the (+) end of the LED to the (+) terminal of the bulb socket and the (-) end of the LED to the (-) terminal of the bulb socket?
or the other way around ...
2) Do I connect the (-) end of the LED to the (+) terminal of the bulb socket and the (+) end of the LED to the (-) terminal of the bulb socket?
Thanks
Question:
Thanks
