Stefan
I recently picked up a dynamo/solar powered flashlight/radio, and it uses a 3.6 volt 0.3 A screw in bulb. I would like to put an LED in there to both be brighter and give longer runtimes. Anyone know if its possible to get a LED replacement bulb in a screw-in base? Most of the one's I've seen available are PR based only.
I'm guessing if there aren't any screw-in based LEDs that I could switch the bulb holder from a screw-in to a PR based.
Here is a background of the unit itself. It can charge a 3.6 volt 300 mAh battery pack by either solar power or wind-up. Information on the unit can be found here.
Anybody have suggestions as to what will work?
