rgbphil
Hi,
Now Christmas time is coming, stores have been stocking LED Rope lights.
A red/green/blue/white/yellow set of ropes plus dimmers will make a nice simple colour changing setup.
The question is will these simple ropes have problems in the long term with dimmers.
I've seen people having trouble with LED lamps with inbuilt regulators and dimmers, these appear to have no transformers or controllers on them, they just appear to have resistors limiting current to the LEDs.
I quickly tested two ropes with an X10 dimmer, and the dimmer could indeed dim the lights, though it had trouble dimming all the way to zero brightness. Presumably the dimmer used the classic triac pulse width method of dimming and doesn't actually drop the width to zero, wherein the LEDs shine with whatever small pulse width is still left.
Anyway, anything else I should know about, nasty spikes etc....or is this only a problem with more intelligent regulation circuitry than resistors? Anyone have actual measured values of dimmer spikes or a link of such an analysis?
Phil
Phil
