ConfederateScott
Could an LED be made that is 12"x12" square? If the tiny ones I see in my Surefire lights make all that light, then how much would a one square footer make? Would it work?
One day I was sitting looking at a bunch of Cree LEDs on my bench and wondering, "what can I do with these?" So off I went trying to make something worthy of the black hole.
The Data Bank 70 uses A123 Systems M1 batteries and aspheric collector lenses. The battery packs are made from Mag 4D tubes. The aluminum plate weighed in at 9lb after machining. It is all one piece of aluminum.
Specs:
70 Cree XRE P and Q bin white LEDs
each LED driven at 1800mA
total power of panel just under 500W
LEDs are three in series to the battery pack
there are two packs of batteries
each pack has normal voltage of 13.2V
33+1 LEDs on battery pack 1 (single LED on an STFu)
36 LEDs on battery pack 2
each pack of batteries is 4 A123 bats in series
each pack of batteries is running over 20A
run time is about 5 to 10 minutes
PF9 pics
Data and Stan671.3
