Had a question regarding resistors in LED series.
For car application, I've been wiring 3 LED series as follows:
+12V-->resistor-->LED1-->LED2-->LED3-->Ground
If I were to switch the resistor placement to the negative side, would each string of 3 LEDs in series still require its own resistor? Or can I wire multiple strings off a single resistor that is connected to ground? I hope the diagram below makes sense- 2 strings coming off a resistor connected to ground. If it is possible to run multiple strings off a grounded resistor, is there a maximum number of strings that can be connected?
Ground
V
resistor-->LED1-->LED2-->LED3-->+12V
Thanks
Ground
V
Thanks
