For just plain superflux LEDs, people have gotten good results with LDO regulators, and brightness control via PWM. I wouldn't consider running any serious LED setup beyond a few diodes off of a resistor. You want lights that work with a 12v supply, and with a 15v supply. If you spec it out for 12v, it will overdrive them at 15v. If you spec it out for 15v, they might not light up at 12v.
better way is to just get a LDO regulator that will give you a stable voltage. still not as good as a constant current driver, but probably fine for low-power applications.
