In the concourse below the tree, they had a small replica of the tree (with the same color LED's) and surrounding buildings was constructed as an exhibit in the concourse space directly below the tree (between the windows to the rink), showing the new solar panels on the roof powering the tree. I had taken a picture of this, and used it as my desktop, and it even stayed all year on the other computer (I since switched to another computer most of the time). It's very blurry, though.
For this year, they have added more whites, creating an overal brighter and less bluish appearance. So it looks even more natural, and a bit closer to the old incandescent lighting. A slight blue deficit would now be located toward the bottom of the tree. The white lights on the trees lining the plaza are now notably dimmer for some reason.
There is also a sort of "sister" tree in Long Island, which last year still had incandescents, but now this year has made the move to LED. But these consist entirely of Foreverbright type faceted C6's in red, orange, yellow, green and blue. Since these strings do not mix the colors with white bulbs, there are now no whites in the tree! (except for the star, which uses the familiar pure white LED's). So it is even dimmer than the Rockefeller tree was last year, and from a distance, the colors blend into an almost ghostly violet glow. The tree three years ago had a few Foreverbrights on the bottom, even though the rest of it was incandescent.
Otherwise, this year has been a bust, as I was not able to find any affordable new addressable RGB strings. I did get 5mm strings of 60; 1 white (Philips), and the other, color (the Philips multicolors were out, and I just saw that the "dome light" version has orange in addition to amber, while the one I got had only amber and the other 3 colors). These I use for the window, instead of the heavier Foreverbright C6's. We now have a little year, so I strung those across a couple of bushes. And the DingDotz (now called X8 Dotz) are still going strong, and the Intellishines still dimmed down for some reason.
