Lens and reflector questions - Maglites
Re: Kd 773 bulb with fire proof bi-pin socket. Do I need aluminum reflector?
sorry but I think your like doesn't work...
anyway, with "hotwire bulbs" (something like more than 10W), in general, you need to get a glass lens and an alluminium reflector...if you don't that they may melt down...
Need Aluminum M*g lite reflector, and lense
I need an aluminm reflector for my m*g lite (that is still focusable) that has a rely good spot beam longer and brighter is better. Also A high temp lense that will be good for the same.
Thanks in advance for your support........
Re: Need Aluminum M*g lite reflector, and lense
I think that if you want to buy them the right section is here...
anyway I have "heard" that FiveMega is going to do another run of his high quality reflectors ( he sells glass lens too)...
if you cant wait KaiDomain sells cammed reflectors in MOP and SMO finish but they are not as good as fivemega ones...(you can alos find glass lenses here )
I wonder why don't you just consolidate all you need into ONE tread, easier to follow up and easier to help you.
AlexGT
you need a metal reflector for sure...
Will this lense increase throw on my M*g
Is this lense going to help me get a better spot lite on my m*g or is it just as well to get cheap glass lense? Multi-Layer Coated HD Flashlight Lens(52mm*2.0mm)
From KD
Re: Will this lense increase throw on my M*g
Edit: I apologize. I misread. If you want a better spot, order the aspheric with Q5 drop in from KD. You will not be disappointed. It makes for a BIG SQUARE hot spot.
Definitely. Purchase the kit with the Q5 drop in. It is a better deal.
Aloha,
jag
From KD
From KD
My understanding is that this is a normal flat lens (2mm thick) with multi coatings. Light transparency will therefore be better, but it will not focus the beam into a spot like an aspherical lens.
Will the Kd ashperical lense work with a regular type bulb or is it only for led? by "regular bulb" I mean a good one (wa1274) or somthing?
An aspherical lens is going to essentially give you a pencil beam thrower. It is commonly used with led's, I dont know if Ive ever seen one used with a hotwire setup however I could be wrong. The reason you need to use a glass lens is because if you are generating enough heat the original plastic lens will melt or severely yellow over time. the flat lens will do nothing, as posted before, to give you better focus. only better light transmission due to the higher value of transparency. the best combination of throw and usable spill beam will be from a SMO reflector, although you will have some bulb artifacts. If you want to smooth out the artifacts with the loss of some throw then use a textured reflector such as the MOP. like wise if you are generating enough heat you will melt the stock reflector, hense and aluminum upgrade is in order. And yes the cammed aluminum reflectors from KD and fivemega retain the focusing ability of the original reflector. hope that helps.
Once played with an aspherical lens in front of my stock Minimag. All that I saw was a little bright glow wire patern on the wall. It works better with LEDs that have a flat square source of light.
