The variable output knob is the biggest feature I see missing from most of the lights on the market, especially at higher output. I don't understand why more manufacturers don't included this - is it because they want to sell us three different lights? Why wouldn't a buyer want to dial in their best light for whatever they need. I just started shopping for good lights, and I've seen so many that want then user to click through (turbo ->) high -> medium -> low -> faint -> strobe 1 -> strobe 2 -> off. This is so annoying, especially because strobe is so useless in the real world. I have a crappy light which does this, and I hate having to press the switch five times to turn it off when on high or to go up one level in output
It makes it tough to find a good, all around light, since most good lights don't have a zoom that can be used to get the intensity just right.
I know the issues with zoom, but even a tiny bit is really helpful in so many situations and could probably be added without much of the usual penalty by using a second optic which rotates in and out slightly along a captive threading. Sometimes you need a wider beam to pick up on things of interest before zeroing in. Other times, that output comes in handy for surveying a wide area even if you're mostly concerned about distance. There should be a happy medium between hot spot and 90+ degrees. Also, a bit of focus helps with a more even light distribution when you do need a wider angle
I have a family member who goes boating regularly and often does overnight trips. The option to sweep a wide patch of water but also illuminate a far-off place like a dock is really important for safety. The wide beam gives a good picture of the water, while the narrow better illuminates a path or destination. At that price point, the light should be versatile and able to handle a wide variety of situations. It would be big, too. Good design could eliminate the need to pack a second.
At that intensity, I'd use a mix of emitters. High CRI comes with an efficiency penalty, whereas high efficiency is more prone to washout. Mixing the two with the right reflector helps up the CRI dead spots in high output mode, while the lower output modes could be configured to use the high CRI LEDs first until more power is needed. With 6x21700, the efficiency penalty of high CRI emitters becomes meaningless when you're running on lower output. If you're on low, it's probably because you're closer in and detail becomes more important.
At that price point, I wouldn't buy it without USB-C and a small LCD showing percentage battery and remaining runtime at current intensity.
