Leupold MX-321 Pics and Review
Imon
The Lone Star State
Greetings fellow Flashaholics!
After recently acquiring a Leupold MX-321 I decided to share my thoughts with you guys.
The first thing that comes to mind when you see this flashlight is "That's a big head!" The second thing is "wow that's heavy" Call me skeptical but I'm hesitant to believe this thing is 6 oz like Leupold claims it is. Perhaps I'm spoiled on my other lightweight lights but the MX-321 feels substantially heavier than my 5.5 oz Streamlight sidewinder.
2AA Maglite for comparison.
Surefire E2L Outdoorsman for comparison.
The packaging.
The bezel. This flashlight is designed to accept Leupold's 32mm Alumina accessories. The name of the flashlight is determined by the parts that made the whole. This is the MX-300 head.
The MX-020 body. The threads are nice and large and came well greased. The back is double O-ring sealed while the single O-ring for the head is present inside the head. The knurling is shallow and doesn't give the user much improved grip over the body or tailcap. There is knurling under the clip area. The flashlight comes with 2 Panasonic CR123a which can be inserted through either side of the body. There is a lanyard loop hole towards the rear and the clip is attached to the body using two 1/16th inch Allen wrench screw.
The MX-001 tailcap. The spring is very strong and does not bend easily. The tailcap can be partially unscrewed to prevent accidental activation.
By now you may have noticed the multimode selector ring and the 4 different modes this flashlight is capable of. The small dot is the low setting of 10 lumens, it then goes up to 100 and 175 lumens and the final setting is a SOS mode at 25 lumens. The selector ring is turned easily and clicks into place. There is no tactile indicator to let you know which mode you're on by touch. The modes can be changed when the flashlight is turned on and I have not detected any flickering while changing modes. The tailcap switch is capable of two modes - momentary on or depressed fully for constant on. Surprisingly the tailcap switch doesn't depress far but take quite a bit of pressure to activate. Keeping the switch depressed just for momentary on requires a firm grip on the body and some pressure on the switch. I have experienced occasional pre-flashes when using the momentary on feature.
Now for some poorly done beamshots! :sssh:
Indoors low mode at 5 feet. The beam is a medium spot with a large spillbeam. The hue is a neutral white that leans a bit on the cool side. By all indications I believe Leupold quotes their output fairly accurately.
At medium mode 5'. I won't bother to show you guys the high mode since both at this distance appear similar on camera.
Medium mode at 45 feet. 4 second exposure.
High mode at 45 feet. 4 second exposure.
Medium mode at 80 feet. 4 second exposure.
High mode at 80 feet. 4 second exposure.
I suppose that's all for now. Hope you enjoyed my brief review and I'll be happy to answer any questions. :)
I'm very new to this brand and would enjoy hearing why you chose this model, what you expected from it before purchase, and how it has met those expectations (or not).
Honestly, more than any other factor, I bought this flashlight because I got a good deal on it and, hey, don't we all like collecting unique things?
As for my expectations for the flashlight I had a feeling there was a good deal of hype and I was almost 100% sure it was NOT going to supplant my E2L as my favorite outdoor flashlight - which it didn't (I'm a big fan of the Surefire TIR BTW). Also, if I want a light that has a greater spillbeam than my E2L I can always go to the Quark 123^2 or for hands free operation my Argo HP (my current pick headlamp).
All in all, I had fairly realistic expectations for the MX-321 so I can't say I was either thrilled or disappointed. I chose this model because the MX-300 head has the largest diversity of modes and the most useful ones for outdoors use. The two things that did shock me however was the size of the head and the weight - this flashlight is a bit hefty. I don't see myself using this on any of my camping or backpacking trips. As many gun owners will call guns they don't fire often this flashlight will be my "safe queen".
It's a shame that they've garnered so little exposure/interest here on the forums. Yes, they're expensive, and, no, they're not the brightest lights on the market, but they have some very nice features, and the build quality is outstanding.
The MX-121 and -131 are particularly interesting. I had another member bore the bezel out for me a little, and it will now accept every P60-compatible drop-in I've tried. (I'm currently running a Malkoff M61 in a Leupold MX-131.)
There's lots more pictures and details in this thread. Wanna take a crack at boring out the main tubes for 18mm cells? :naughty:
...and they appear to have new packaging.
Thanks for the review and I totally understand wanting to collect unique light's. The build looks great but you didn't mention where you bought it, If I wanted one I don't think I would know where to look or rather the best place to look. Is there any green tint to it, it almost appears to be but I know sometimes the tint don't look the same in real life.
Edit- Found them at Opticsplanet..wow pricey
I don't mean to be circumspect but I got a special incentive price on this - it won't really help to tell you where I got it because these deals aren't open to the general public but it was about $140. In retrospect I should have spent that money on a RA clicky :duh2:
As for the beam it doesn't have a green tint - it's more of a cool-ish neutral white. Must have been the wall color that threw you off - the wall is slightly beige but doesn't appear that way in the photo.
Also, gswitter, I can hardly refrain myself from boring out the flashlight body :p
