James S
Hi Folks,
Finally took a new set of NiMH batts out of the charger and popped them directly into my brand new LGI.
The potential problem is that NiMH batts have a lower internal resistance than regular alkalines and so even at their lower voltage may dangerously overdrive the Luxeon.
With brand new alkalines this light pulls as much as 1.2 amps. With the hot NiMH's I measured 1.45 and it's dropping off quickly. After only about 2 minutes of running it had dropped to 1.2 amps.
The head did indeed become warm, but not noticeably more so than with fresh alkalines. I don't think that as long as the luxeon is adequately heat sinked (sunk?) there will be any problem.
However, keep in mind that the NiMH AA's that I'm running are a couple of years old. If you have some brand new super powerful ones you should test the draw yourself before assuming you're not cooking the LED.
People using bigger NiMH's like C's or D's should definitely check the power before using them in direct drive LED lights. These cells pack an even bigger punch than the AA's. But the AA's appear to be OK.
I know that everyone already knows about NiMH and this whole story, just thought I'd add my 2 cents
Thanks,
James
Thanks,
James
