Li-ion under voltage protection?
What voltage would you like under voltage protection set at?
  • 2.80v or higher
    Votes: 13 52.0%
  • 2.75v
    Votes: 7 28.0%
  • 2.50v
    Votes: 5 20.0%
  • 2.30v
    Votes: 0 0.0%
  • Total voters
    25
jasonck08
Redding, CA
So far I've tested a number of so called "protected cells" that claim to have under voltage protection. The standard figure that most li-ion manufacturers give you is that the low voltage cutoff should be 2.75v. Most cells the cutoff seems to be <2.5v. Why is that?
Why don't companies select a better quality more on spec IC that properly cuts off somewhere around 2.75v?
If you ran your cell down to the low voltage cutoff every time, you would be doing damage to it by brining it down to 2.3-2.5v (where most protection circuits seem to kick in).
So the Today's poll is, What voltage would you like under voltage protection set at?
I didn't vote, as there are just too many variables to consider. As protection circuits are applied and used now, it would seem that the manufacturers recommendation would probably be the best, as different manufacturers likely have different requirements, due to slight differences in the cell's makeup. What value it would be therefore, would depend on each manufacturers individual cells.
As to the QC control you've observed on many protection circuits, I agree, this is a problem. Every once in a while they don't even work at all! It doesn't seem that until the tolerances and quality of the components used in these circuits is improved, that it really makes sense to pursue this endeavor. :sigh:
The protection circuits added to loose LiCo cells by distributors (note that Li-Ion cell manufacturers refuse to provide loose cells with protection circuits) are not a convenience item to remind the user that the cell needs to be charged, but rather a last ditch safety effort to prevent an over discharged cell from being charged and possibly "venting with flame". It is there to protect the user, not the cell.
As for discharging cells to the cutoff point of the protection circuit, you're screwing up your cells to some degree, anytime you discharge them below about 3 volts under load anyway, depending on the current value. So, discharging cells until the protection circuit cuts out, is just a really bad habit to develop.
Now, if what you are suggesting is a protection circuit that is more to protect the cell, and not the user, then I think I'd go for something in the neighborhood of 3.0 Volts. The problem is that this value would actually vary greatly, being dependent on the current load under which the cell is used. For low current uses for example, the value would be necessarily higher, and for high current drain applications it would have to be set lower.
This is where the problem with your idea is. There is really no way for the distributor to know how the cell is going to be used. This is already a problem with current protection circuits, as they are now. Short of providing protection circuits with different cutoffs for various current loads, and, as a result having to provide many versions of basically, the same cell, it can't really be done. I don't foresee that happening.
The best solution is to provide protection circuits within the device, as Laptops, power tools, and some lights do. Many of my lights have this feature, and allow the use of unprotected cells, which solves the problem entirely. :)
Dave
Dave
Now I know there are some differences between various LiCo cells and their chemical makeup, but I think generally Li-ion cells are designed to be discharged down to there minimum cutoff voltage of 2.75v for example. There are some exceptions (ie Panasonic 2900, which has a 2.5v cutoff)
I've done quite a bit of testing and if you're discharging at say a low current say 500mA, and discharge down to 3v instead of 2.75v, the difference in capacity for a 18650 battery might only be about 50mah. but if the cell is under higher load say 3-5A, the difference in capacity between 2.75v cutoff and 3v would be 200-300mah.
In my personal opinion I think Li-ion cells low voltage cutoff should be as close to the manufacturers specs as possible. I guess one of the problems with this is that with many of the cheap protection PCB's out there, the tolerances on the IC's can be more then +/- 100mv.
I've been testing some good quality IC's lately made by Seiko Instruments (Made in Japan) and they do a lot better then your normal Chinese IC's. Cutoff tolerances in most cases are greater then 50mv.
