LiFePo Vs Nimhy
VidPro
Lost In Space
Li-Ion has a huge weight advantage over ni-mhy, and power for size.
but what about li-fe-po?
if extreeme amps were NOT needed
if the voltages were relative (meaning the voltage is not an issue)
if recharging is needed, and capacity for size/weight is important
if there will be overcharge, although very limited and slow
if weight was a big issue?
does a similar wattage total of li-fe vs ni-mhy weigh less or more or very similar?
would a similar wattage of li-fe vs ni-mhy handle overcharge worse or better?
when u say 'wattage total' reading between the lines do u mean 'watt-hours'?
doing a simple divide of watt-hours into basic cylinder volume & weight:
......... Elite 23430 5Ah NiMH ......... A123 M1 26650 2.3Ah LiFePO4
capacity ............. 6 Wh .................... 7.36 Wh
volume .............. 17.9 ml ................. 34.5 ml
weight .............. 67 g ..................... 70 g
Energy Density .. 335 Wh/L .............. 213 Wh/L
Specific Energy ... 90 Wh/kg ............. 105 Wh/kg
subject to peer review.
do not know about overcharge capability cuz i'd rather just avoid it altogether.
i hope this is what ur askin4.
yes it is thank you.
so what you have here is pretty similar in weight vrses "power"?
that is what i needed to know. because i have ni-mhy working fine in the situation, and li-fe-po popped into my head , i thought mabey it could save weight.
I assume your talking about NIMH since there isn't such a thing as nimhy?
Same things as any of the other lithium based, lower overall life span, more complex chargers, etc.
Here is a comparison table with other chemistries as well:
http://www.batteryspace.com/index.asp?PageAction=VIEWCATS&Category=1272
Lithium Iron Phosphate (LiFePO4, LFE) is new generation Li-Ion rechargeable battery for high power applications, such as EV car, Power Tool and RC hobby. LFP cells feature:
high discharge current, non explosive, long cycle life ( >2000 ), but its energy density is lower than normal Li-Ion cell (Li-Co) (higher NiMH cell). LFP cell has 3.2V nominal working voltage and shall be cut-off power at 3.6-3.8V per cell during charging. Please see the table below to see comparison between LFP and other rechargeable batteries. LFP battery has the lowest cost if considering its long cycle life.
hmm, that chart shows a much better weight for the li-Fe.
although i was (sorta) asking in the forum, to get "user" input, based more on reality, and what the actual avilable Cells to us are.
you know just a , i got these and they arent light, or they weigh a lot more than li-ions.
so i looked further into , then found this
http://www.batteryspace.com/index.asp?PageAction=VIEWPROD&ProdID=4053
very new, and the pic seems to be just a photoshopped one of these
http://www.batteryspace.com/index.asp?PageAction=VIEWPROD&ProdID=3483
so i dont think a lot have been purchaced yet.
and as you can see its not immediatly available.
but i compare it directally to the similar li-poly, and the weight differential isnt to bad, ON PAPER :-) guess i will have to get one and see what is real.
