About 10yrs ago I mounted a light on a shotgun. Things have changed - hopefully improved. The number of lights available now is bewildering - so I now need expert help to make a good choice. My regular lights tend to be Fenix - I like the tough build and they have been very reliable - perhaps a good benchmark.
I recall that last time I looked at shotgun mounted lights it was important to have a spring each end of the battery compartment so that it could withstand the recoil. Lights now may be tougher and not need that.
I have a tri-rail mount on the ammo tube and am going to use a 1" scope ring to mount the light. So, my requirements are:
1" tube diameter
Ideally not too much bigger at the head
1000 lumens or more
White light
Flood beam, I anticipate 25 to 50 yards max range, but would like to illuminate a wide area at 25.
Robust
18650 battery compatible (I have a good supply of rechargeables)
Exposed clicky tail switch for easy on-off with forward movement of hand
I'd prefer to keep it simple, so 2 modes (say 1000 and 500) would suffice, but I could live with more if the interface was not too confusing, and I'd prefer not to have on board charging.
Input appreciated
1" tube diameter
1000 lumens or more
White light
Robust
Input appreciated
