kramer5150
We often hear about the "quality" of emitted light. The lights ability to reveal textures, penetrate through surface shadows and accurately render color. To some it's a kind of abstract entity. To put it into words, its like seeing through the leaves and twigs and seeing the bark or mossy texture of a tree trunk. Only my brightest LED lights really possess this ability… or so I thought.
The video below is a 1 minute portion of the beamshot review of my shiningbeam.com RC-N3-Q5. Look closely and you can see how superior quality this light is to the DX:6090 (Cree P4) at illuminating deeply into the small shrub. The RC-N3-Q5 lights through the shrub, past the leaves and sticks and projects light onto the window behind the shrub. You can see a small little reflection off the glass right in the center of the shrub, it looks like a bright dot right in the middle. Notice how when I toggle back and forth between the RC-N3 and 6090 that reflection comes and goes with the deeper-penetrating light. Notice how also the deeper penetrating light is NOT the most luminous. The 6090 clearly emits more lumens, yet is unable to project light THROUGH foliage like the RC-N3-Q5.
Pretty phenomenal, when you consider the RC-N3-Q5 was powered at 3V with a semi-used primary, and the DX6090 was being run at 8.4Volts with two RCR123 cells.
I had to go back outside and inspect the shrub and make sure there wasn't anything shiny or reflective in there... NADA, that bright spot you see in the vid is light reflcting off the window glass through the foliage.
FWIW, I held both lights right next to each other in the video. Tactical holds in each hand. The heels of my hands were pressed against each other, thumb clicking back and forth.
Heres the vid...
http://www.youtube.com/watch?v=_ztQVtsH9-w
Heres the vid...
